跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
The lid will not come off
i have tried everything to get the lid off the playstation 3 slim and will not come off at all. what should i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
I don't know why no one will answer this question clearly, this is the third forum I've seen without it. There is a HIDDEN screw, even sneakier than the ones under the black square pieces - it's underneath a BLACK STICKER WITH TEXT ON IT, right on the bottom of the PS3, hiding in plain sight. You have to PEEL OFF THE BLACK STICKER to reveal another of those black plastic squares, which after removed will reveal the final screw. (caps for clarity)
这个答案有帮助吗?
得分 7
8条评论:
I've seen "remove the seal", but that doesn't convey what you're looking for. Again, on the bottom of the PS3 where all the other screws were, close to the center, there's a black sticker with text on it. You have to peel that sucker off, and voila. You're not crazy, I'd guess probably 82% of people fall for this like I did, because it's a total curveball. Like a trapdoor under a rug.
由完成的
@Chris B thanks man you are a life saver
由完成的
God Bless you Chris frustrated i was about to go hard way and most defiantly damage
由完成的
Thank you so much. I was about to break this $@$* even more, lol. You're the man! XO
由完成的
Saver
由完成的
显示更多的3条评论
添加一条评论
Make sure all screws are taken out. There is one that is under the seal. That one is usually the one that people forget to take out.
这个答案有帮助吗?
得分 2
2条评论:
i took out all the screws even the software but the lid would come off from the front where you insert the disc only the back of it would come off. any recommendations please?
由完成的
Same nothing worked
由完成的
添加一条评论
You prob missed a screw. Look at the guide on here and make sure you did it correctly.
Or just jerk it real hard. It'll come off
这个答案有帮助吗?
得分 0
1条评论:
i did that i have used a tool to ply the front top lid off of the PlayStation and it will not come off at all
any idea what i can still do?
由完成的
添加一条评论
I hade the same problem There's one more hidden screw found out the hard way
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marioehusari 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 50
总计 9,048
