跳转到主内容
数百个光盘驱动器的维修指南。
28 个问题 查看全部
Can the optical drive from an A1095 be installed into an A1150?
The optical drive in my MacBook Pro A1150 died. I have an old PowerBook G4 A1095. Can I install the optical drive from the PowerBook into my MacBook as a stop-gap measure?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The optical drive from your A1095 PowerBook is too thick to fit into your MacBook Pro, unfortunately. Of the original MacBook/MacBook Pro line, only the 17" MBP's can accommodate the 12.7 mm thick drives.
Sorry!
这个答案有帮助吗?
得分 3
1条评论:
+1 Ralph
完成的
添加一条评论
The PowerBook G4's use PATA Optical Drives, and most likely has a 4X or 8X SuperDrive. The A1150 appears to be a PATA drive as well. It should be compatible, unless the thickness is a problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
micgreyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,719
