跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
Can I add hard disk drive in Mac mini with fusion drive?
Hi,
I have 2 linked questions.
Is there still the space to add a hard disk drive in Mac mini with fusion drive or is this area filled by fusion drive?
If it's possible did the additional hard disk drive will be considered as part of one disk or will it appear as another hard disk drive with no benefit of fusion drive?
Thanks for your answers :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
It would appear as a second HD and AFAIK not have any benefit of the fusion drive. See this article
If this answer was helpful please remember to mark it accepted.
这个答案有帮助吗?
得分 1
3条评论:
Thanks but there is a point I still don't know. Where in physically the SSD drive in mac mini fusion drive? I'm afraid it use the area for second hard disk drive?
完成的
You're correct reports are the fusion drive uses one of the drive bays.
完成的
A Fusion Drive is two physical drives (1 HD & 1 SSD) which via software made as one contiguous volume. You need to use two SATA Ports and drive storage spaces to create a Fusion Drive.
完成的
添加一条评论
最有帮助的答案
After digging through the manuals for this machine, it appears that the Fusion drive configuration uses both drive bays. The SSD goes in the lower bay and the standard hard drive goes in the upper bay (these bays appear reversed when you're in the machine).
If you ordered the machine without a fusion drive, you still have an empty bay.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
glenic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,628
