I had the same problem with my S3. It took awhile to show up, but eventually one of my earphone jacks stopped working.
I ordered this part from etrade supply:
OEM Samsung Galaxy S III SCH-I535 Loud Speaker Module ,Black
Item# ESSAM10311355-23
There are instructions online, that a very straightforward. unscrew all the screws from the back, GENTLY, pry the case apart, and replace the top part containing headphone jack and loudspeaker. One caveat that wasn't made clear is that it is a little tricky to actually plug the new piece into the phone. Don't use too much pressure, but it does plug in when you line it up properly. This step wasn't well explained. Now my phone headset works like new. It's only been a few weeks since I replaced, but it cost me about $35 for the part and a mini screwdriver tool including shipping and handling. If you have an eyeglass screwdriver you probably don't need to buy a multi-tool. I have an I535 but the part I ordered didn't list my actual model number and it still worked.
Got an S3 Spet 2012 and the sound worked fine for about 5 months. Then the same problem others have, no sound from right side. Got a new phone (much hassle) and now the new phone has same problem. When I contacted Verizon for the replacement I was told they had never heard of this problem. Sounds like BS. For what is suppose to be a top of the line phone, what a piece of junk. And to add insult to injury, there is the continuing difficulty in getting computers to recognize the S3. I will never own another Samsung.
由 Mark 完成的
I am the original submitter of this question. I had a phone with a bad jack and the sound only coming out of the right ear. After 6 months of using bluetooth headsets for music I got a replacement phone from AT&T. 1 month later I am experiencing the same issue but now with the left side not playing any sound.
由 davin cleary 完成的
I'm facing dale issue with my s3 mini.
I can't hear anymore on the right ear.
I've tested the hear phones on my s5 and there's nothing wrong.
besides there are lots of other issues with s3 mini while listening music such as music sudennly stops.
I start getting !#^&@@ of with all this $@$* with.
由 Carlos Carvalho 完成的
I have a samsung galaxy s3 & i have trouble using headphones in my phone. I will play but its like the headphones are blocked & you can not hear any singing or bass when headphones are plugged in. I have tried at least 3 different type of headphones to see if my ones were just faulty but its the actual jack in the phone. How can i get this fixed at a cheap price?
由 Renee Mclean 完成的
Samsung ear bud doznt last even a year......its a $@$*
由 rehaanhassan 完成的
显示更多的8条评论
