跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
Replaced Proximity Sensor and it and the on/off do not function
The part arrived and I spent all night until 5am to replace it. Now no functionality. Did I stick it on backwards or something? The bloody button clicks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Sorry that didn't work because that is quit a time consuming job, sadly you need to do it again, if your lucky you didn't get the new cable plugged back into the motherboard, check that first, if it's not that then re-step everything you did and try to find something wrong and correct it, if you cant find a problem you might have bought a bad cable and will need another one, good luck. iPhone 4 Power & Sensor Cable Replacement
这个答案有帮助吗?
得分 1
1条评论:
Thank you. I hope it will be faster to do again now that I understand the steps. However I would rather avoid having to do it multiple times.
Since the button is clicking I take that as a sign the original bracket is not broken. Also I don't know that there was an actual plug on the thing to snap in. Is it more of just a contact?
The part I ordered was from china for $5 but appears to be new. Perhaps I should order a new bracket JIK.
完成的
添加一条评论
添加你的答案
roundo32 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 253
