跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Why is my LCD weak when touched and dark corners?
When touching the screen ever so slightly it shows the same characteristics that would happen when you really push a screen hard, especially around the edges of the screen. As well as this there are dark areas in every corner of the screen. is this the LCD or the backlight?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Sounds like a bad connection likely to the data display cable or the control board for the LCD most likely on the back of the screen... your putting pressure on the corners causes the display to rock, stressing the short or connector.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jamie Horn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 397
