跳转到主内容
所有制造商和服务提供商的手机的维修指南和拆解信息,包括苹果 iPhone 和三星 Galaxy 系列。 获取您亲手维修手机所需的一切资料。
73642 个问题 查看全部
Solder type to use on cell phones
Im looking on working on some charge ports for many cell phones and was wondering what would be a good soldering wire to use on cell phone pcb's, Size, Ratio and lead or lead-free. Any suggestions would be appreciated. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What wou8l;d be a good flux and acid free or acid flux
完成的
i know this post is old, but im getting into doing some deep hardware editing… like using an s8’s board and connecting it to a different external touchscreen, and inserting the hardware into a new handmade case. This was the result of my first search. thank you guys for assuring me things like this are possible
完成的
添加一条评论
2个答案
已选择的解决方案
Most, if not all devices are now assembled using lead free solder as it is a requirement to be in the European market (ROHS) I would suggest using something like 1mm Lead Free Solder
Lead-Free Solder图片
产品
Lead-Free Solder
这个答案有帮助吗?
得分 2
添加一条评论
I use 63/37 lead solder to repair most smd components. I use 62/36/2 to solder charge ports. I always use a good quality flux it can make a world of difference in the solder quality.
这个答案有帮助吗?
得分 1
2条评论:
Craig do you have an email? I have some questions.
完成的
Craig you mentioned using a specific solder and flux. Can you provide the product info for both. I need to repair a Samsung Tab 3 7.0 charge port that requires soldering.
完成的
添加一条评论
添加你的答案
retlaw23559 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 33
总计 13,351
