跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
White screen after replacing LCD?
Before I closed the ipod up I turned it on to make sure everything was working and they all were. So I snap the glass on and next think you know the screen is white. Can't fix it from home + power, volume + home + power, or restore. Any advise would be great. Checked connections several times and have tried another screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
DFU mode restore didn't work. Not sure what to look for on the logic board. I compared the area on the right of the lcd connector to that of a new ipod and they looked the same to me. The connectors aren't missing any pins
完成的
添加一条评论
1个答案
最有帮助的答案
If you have tested with another LCD and having the same issue and all connections are proper then you might have a bad logic board. Some things you can try DFU Mode then restore. Test to make sure the LCD works. if the DFU mode restore didn't resolve and the LCD is working then your logic board is what i would look at next.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Doug 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,156
