跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Ps3 won't work on hdmi cable. No signal
My ps3 won't work!
It has a hdmi cable but no signal!!
I tried different ports and different cables
But no luck. I also tried holding it down to reset the video settings but still no luck!!
PLEASE HELP I JUST BOUGHT IT LAST WEEK
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
you say diffirent cables, you mean hdmi or also scart?
完成的
it won't work
完成的
I have no on or off switch on the back of the ps3
完成的
try using the compant cablde for the ps3 #the ps2 video cable
and then go to settings - video setting than click the first one than go to the top of the line you should see hdmi and than click x than x again than switch to hdmi
完成的
Hi I have a PS3 and the HDMI port and AV port both of them do not work they glitch out when I try to plug any of them in and they have like lines and red and green square glitchy things in it what does that mean
完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
1 make sure tv or monitor is on and change source to proper input IE Hdmi 1 or 2 etc.
2 Ensure your ps3 is off but ready to be turned on. Fat ps3 has switch in back that need to be in on position.
3 hold power button for 5 to 6 seconds and let go after 2nd beep, it should come on with a beep and wait for 2nd beep.
4 this should reset your video, if display flickers then it should come up.
5 if it doesn't, try turning the power off then on again. Repeat steps 2 to 4 if it doesn't work.
If you keep trying and it doesn't work, then your unit might have to be repaired.
这个答案有帮助吗?
得分 5
7条评论:
Mine does this no video at all
完成的
Worked great ty I was freaking out for a second..lol
完成的
Awesome! Thanks
完成的
What part would need to be replaced?
完成的
Tried it today and it worked like a charm the first time! Thank you!
完成的
显示更多的2条评论
添加一条评论
PS3 80gb super slim it has a black screen and no singal what is wrong with it
这个答案有帮助吗?
得分 1
1条评论:
Same here ! We'll my 150gb is working find but my 500gb slim that has been in my closet for a couple is doing just this ! I tried multiple cables and tested it with 3 different screens. All no signal
完成的
添加一条评论
添加你的答案
Jesse 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 171
总计 66,340
