跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3787 个问题 查看全部
No status light on magsafe cord
This morning my MacBook was fully charged. I know becuase the light on the magsafe cord was green. When I went to charge my laptop a few hours later, I plugged in the power cord and the light doesn't light up. Also, on my desktop, where the battery time is at the top, it does not say "charging". I am assuming there is something wrong with the magsafe connection. I had to replace my original power cord about 10 months ago. All the connectors appear clean and have worked up until today.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
First you should try either of the following to diagnose what's wrong:
1) Try the charger with a different computer, see if it works
2) Try the computer with a different charger, see if it works
If the charger works with a different computer then you need to replace the dc-in board on your MacBook (tell us which one it is and we'll link you). If the computer works with a different charger then the charger is broken and should be replaced. If the computer does not work with a different charger then it's a bad dc-in board as well.
这个答案有帮助吗?
得分 3
2条评论:
+1 Ralph
完成的
Thanks
完成的
添加一条评论
添加你的答案
Travis True 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,967
