跳转到主内容
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
iPad now in Boot Loop after multiple battery replacements
Replaced the Battery & Back Housing to an Original iPad and now it is in a boot loop & won't charge past a certain percent. I've tried replacing the charge port and tried multiple batteries from different distributors. Tried resetting the settings & reloading with no success. Didn't have this problem prior to battery replacement
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
Try this. It worked (after a few tries) for a friend who had the same problem.
1. Unplug the iPad from the USB charger cable.
2. Press and hold the power button (it should not turn on because the battery should have run dry).
3. While still holding the power button, plug the USB charger cable in (it should not turn on yet).
4. Wait for at least 60 seconds while still holding the power button.
5. Once the iPad powers on, immediately let go of the power button and pray.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
iPads have a fault that sometimes puts them into a boot loop (dead battery logo, then apple logo, and repeats over and over when on a charger). This is caused by a completely dead battery on an ipad that was not powered off properly. The ipad thinks it is suppose to stay on, but the battery is dead. So when you plug in the charger the ipad immediately tries to turn on but is so dead it shuts back off and repeats.. There are a couple of fixes for this, but this is the easiest one that I have found.
All apple devices have a temperature protection circuit that will turn off the device if the temperature gets either too hot or too cold. If you put the device in the freezer for about 45 minutes and immediately put it on a charger when you take it out it will allow the device to get enough charge to properly boot up.
Note: If you have already tried to restore the device you will need to hook it up to itunes and complete the restore after the device has a decent charge (10% or greater).
Hope this helps others, it has worked for me.
这个答案有帮助吗?
得分 5
4条评论:
Thank u so much it really works!!!thank u very much!!!!u saved my lot money tq tq tq tq.....
完成的
Thanks for this I'm going to give it a try with a 1g I have
完成的
It did not work for my iPad 1st gen 64GB 3G. I put it in the freezer for 1 hour, removed it from there and plugged the charger immediately, still on the boot loop with the Apple logo. I also tried the opposite, let it under half-day sunlight for 1 hour, the temperature went up to 60 degrees Celsius and the Apple logo startup loop persists.
The iPad was unused for about ~3 years and the battery seems completely dead.
完成的
i've seen all the videos where the hair dryer is used, but no one explained why it worked. Thanks so much
完成的
添加一条评论
i will try today and get back
iPad Air 2
这个答案有帮助吗?
得分 0
1条评论:
did it work for you?
完成的
添加一条评论
put it in the freezer for 45 minutes and charge it agian
这个答案有帮助吗?
得分 0
1条评论:
I tried this a couple of times, unfortunately didn't worked for my iPad 1
完成的
添加一条评论
添加你的答案
Jenna Wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 76
总计 11,630
