跳转到主内容
Magic Box modifies your existing Apple MagSafe Power Adapter to use HyperMac/HyperJuice External MacBook Batteries
问题已关闭
How do I use the MagSafe Charger w/o the HyperMac Battery?
Saw the Calli video about the mods. No problem. If you wanted to use the Apple Charger straight to the MBP, where is the hook up?
Also, In the illustration on Connection 3 at the bottom, it shows a separate cable from Box 2 to Battery. No one ever talks about that cable. Can you pls explain?
(or is the illustration wrong?)
Txs
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First, I've not used a HyperJuice. In looking at the diagram I think it's clear what they do here.
Once you cut the cable your connecting a box at each cut end {Yellow & Blue ends} (fig1). Then you use an interconnecting cable to attach the two boxes together to power the MBP with the MagSafe charger (fig2). If you split the boxes apart you can then attach the HyperJuice battery to the charger or the system (fig3 or fig4). I suspect the interconnecting cable is part of the kit {White cable}
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,034
