跳转到主内容
问题已关闭
hang up glass on MacBook Pro after lcd replacement
Hello to all guys, thank you in advance for the advice.
I wanted to ask you a question, I have to disassemble the lcd of my macbook pro mid 2010, but I have a question, after I removed the glass and replaced the lcd panel I'll have to remove the glue on the inner frame and reattach the glass (the glass is not damaged then reassemble his original) or I can simply plug it in again without any cleaning of adhesive?
Thank you all
Andrea
(from ITALY)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
1) get a towel or some soft surface
2) get a heat gun or a hair dryer and heat up all the adhesive for about a minute
3) scrape all it off with a plastic pry tool or finger nail (be careful not to #*&! up the paint on the inside)
4) apply new adhesive.
Done hope it helped bro
这个答案有帮助吗?
得分 0
1条评论:
Thanks Scott I've been very helpful! I figured the process was so but I have to remove the adhesive from both the glass from the frame inside?
thanks again
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 422
