跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
Power button not working after flex cable replacement
Hello,
I have an Iphone 3gs that the power button didn't work so, I replaced the flex cable thinking that it was bad. Wow, what a feat! I got the phone re-assembled and it still does not work. All of the other buttons, volume up/down, mute switch, headphone jack, work as they should. This is the same behavior that it was doing before I replaced the flex cable. Is there something on the logic board that is causing the issue? I don't want to go through the painstaking task of putting in another cable. Is there something else that I can try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
are you sure it makes good contact? sometimes i have to bend the 2 legs a little
这个答案有帮助吗?
得分 0
1条评论:
Yes, I double checked the connections. Like I said, the volume buttons, headphone jack and the mute switch all work just fine. It's just that darn power switch.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 485
