跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
Will unit work without screen attached?
I got an iPod that was smashed up pretty bad, but seemed in not bad shape. The ribbon cable attached to the lcd has come completely off the screen. Can this be re atttached? Also, will the unit no longer sync with a computer because the screen isnt attached?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
I plugged in a parts iPod I got that is a 2nd Gen to my laptop and Itunes recognized it and saw that it was a 8 gig model with nothing stored on it. This parts iPod did not have a Touch Screen or LCD installed. This does not prove that it will work correctly if I install a new touch screen and LCD but it did prove it was not totally a dead 2nd Gen iPod
这个答案有帮助吗?
得分 1
添加一条评论
It should, the only problem, is that it you want to do anything with it, other then have a $300 flash drive, you will need to install a screen, since the only interfaces it has other then the screen are the lock, home, and the volume switch. You should be ablt to sync it, but you may run into the issue of a passcode lock. If there is a password, you will need to unlock it, and with no screen, that may be quite challanging. You could put it into DFU mode, restore it, then you can sync it with no problem.
这个答案有帮助吗?
得分 1
添加一条评论
My ipod felt the screen smash and it didn't work.What should I do to fix it.
这个答案有帮助吗?
得分 1
1条评论:
start your own question for that - it would be the first step
完成的
添加一条评论
添加你的答案
ian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 6,542
