跳转到主内容
加入维修社区 - 创建账户
2.26 or 2.4 GHz / White plastic unibody enclosure
Numbers 1-9 won't work (possible num lock issue?).
Thanks in advance. I have macbook a1342, and it appears that maybe the num lock function is off (although 0 works). The number keys 1-9 suddenly stopped working (mid session). I stupidly restarted my computer hoping it would help, forgetting my password has numbers in it. Ugh. I've tried a few solutions but none have worked and its hard to search on my phone. I tried the suggested fn+f6 as well as hitting option 5 times in a row, but neither worked. Thanks for any help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
Can you plug in an Apple USB keyboard? That might let you enter in your password and then you could try using Apple HArdware Test as well as make sure your OS & firmware is up to date.
完成的
I'm not sure if my last comment to you showed up Dan. Thanks so much for the help! I did the hardware test and everything was fine, it said. I also updated my computer. The problem is still there, unfortunately. Do you have any ideas?
完成的
So you were able to gain access via the USB keyboard using the number keys on it - correct? If that is so then it sounds like you need a new keyboard.
完成的
i dont have an answer i have the same problem
完成的
Can you tell us what keys your having problems with and what happened when they stopped working. Have you likewise run Apple Hardware Test and checked your OS & firmware? Does the Apple USB keyboard work? And lastly is your system the same as Carrie's?
完成的
添加一条评论
1个答案
已选择的解决方案
Carrie - Replacing the keyboard is a big job in this model as it's part of the upper case. Here's the steps to replace the case iFixIt Guide. Once you have it off you might be able to clean what ever got spilled (if that) by taking the keyboard apart.
If you think this is to big a job for you to tackle I would bring it into an Apple Store and let them do it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carrie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 5,600
