跳转到主内容
The Motorola DROID 3 is a smartphone by Verizon Wireless running the Android 2.3 operating system by Google.
9 个问题 查看全部
问题已关闭
Droid can not find service
Phone dropped in water. After 24 hrs. phone powers up but can not get service. Does radio need to be replaced? How would I replace radio? Does it just need to be taken apart and blow forced air into parts.
Help.
Many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Several things can cause this. If the phone was dropped there may be a connector problem where the antenna flex cable has popped out of the socket I haven't worked on this phone but they are essentially all the same inside.
Check the setting under network and see if you are searching for a roaming network or make sue the settings are set to your network
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 489
