跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 个问题 查看全部
What's the best way to install a new throttle cable?
I got some awesome tips on diagnosing my moped's stuck throttle cable problem. The solution seems to be to install a new throttle cable.
Therein lies yet another problem. The throttle cable routes through the frame of the moped. What's the best way to route the new throttle cable through the frame without taking the frame apart (if taking it apart is even possible)? Once I get the cable through the frame, how do I connect it to the actual throttle on the moped?
For reference to the original problem, take a look at my throttle cable teardown.
Thanks a lot!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
depending on the cable (if it has 'solid' parts, and at which end) you can tape the new cable to the old one, or tie it together with wire, and use it like a guide wire to pull the new one threough.
which direction depends on the situation.
With a bit of skill, most of the time it is possible (and not too difficult) to just poke the new cable through the frame (it is stiff enough to be guided. Believe me, these cables have to be replaceable, and easier than iPod repairs!! :) good luck
这个答案有帮助吗?
得分 3
1条评论:
Awesome, thanks. I think I'll try to braze the old cable to the new one, and then pull on the old and push on the new!
完成的
添加一条评论
^ what he said.
hey - connecting it to the throttle - if you take the old one out you see how it is fitted. You are talking the twisty thingy?
这个答案有帮助吗?
得分 -1
1条评论:
This should be a comment on Spikey2's post. Delete this answer to gain back the reputation lost from the downvote I just made on this answer.
完成的
添加一条评论
添加你的答案
Miroslav Djuric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 5,974
