跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
SSD instead of the Superdrive with Optibay? Possible?
Is ist possible to put a SSD instead of the Superdrive? (perhaps with an Optibay?)
Is there a tutorial on the net ?
thx
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Here is one persons solution. Will it work for you--read and decide.
Good luck--Ralph
http://forums.macnn.com/58/iMac-eMac-and...
这个答案有帮助吗?
得分 2
添加一条评论
hey thx!
i think i will put a 2,5" HDD with an Optibay instead of the Superdrive and replace the old 3,5" HDD with a SSD (Intel).
这个答案有帮助吗?
得分 0
添加一条评论
worked for me. Put an OCZ vertex II in a MCE optibay and the superdrive in the provided superdrive case. Now after almost a year, i can use my 250 gb ssd drive , at 3GB link in my macbook pro mid 2009. Good luck you guys,
JP
这个答案有帮助吗?
得分 0
添加一条评论
hey guys,
what about boot? could it boot from usb superdrive?
thanks!
这个答案有帮助吗?
得分 0
添加一条评论
I did this with an eBay version of the Optibay. It worked, except that I botched the video cables (Vertical Sync AND Display data cable). The display had vertical bars across black areas of the LCD. It was barely useable for basic tasks like web browsing. Turns out that I'd bent/broken some of the Display data cable connectors, which are mounted on the logic board. New logic board is $1600...
Ended up buying a new iMac. Oops. Be Careful.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
t3lly 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 31,945
