跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Replaced iPhone 4s Display And Battery Now No Service? Help
Hi, I recently attempted to replace the front and back cover to my iPhone 4s, lack of concentration in the beggining lead me to remove the battery without unscrewing/unplugging the connector and tearing the ribbon straight off the battery.
I was fuming but then proceeded with much concentration to change the display, taking care on everything i did and ordered a new battery for the phone.
A few days passed while i was waiting for the delivery so I could not check if the phone worked straight away, after i fitted the battery and after seeing 'searching...' for 5 minutes, it appeared with 'No Service'. Could not call or text from it or recieve either.
I've taken the phone apart 3 or 4 times now trying to work out what i may of done wrong but all i have seemed to do is round the screws after so many failed attempts. (New screws on the way).
There are a couple of times where i have had a signal, mainly either 1 bar or full bars but then i try to ring out and says call failed, then back to 'No Service'.
I have read through pretty much every question and solution on this website and still no joy.
The phone;
Is on UK Network EE
Recognises my SIM card
States the correct time and date
Connects to Wifi
Was on iOS5 when I first had the issue
Has been updated to iOS6
Has been restored to factory settings
Does have a few screws missing due to rounding off the screws (Hopefully new screws arrive soon)
Im unsure what a blue resistor looks like, let alone where to find it so im unsure if that is the issue,
Im really getting annoyed now all this bother just to get a shiny blue screen, somebody PLEEEASE help before I launch it at a brick wall!
Thank you
Dave
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This may be an un-reparable situation but make sure the slimy black cable going from the bottom dock to the right of the spot where the battery connects. You have to make sure this clicks in perfectly. If you think this may have been damaged then I suggest buying a new dock (Follow the cable to the new part that you need.
I hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,501
