跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
How can I repair my iPhone 3GS' speaker and motion sensor?
HELP! I replaced the glass with an iFixit part and guide, for my iPhone 3GS speaker and now the motion sensor and iPhone ear speaker (not speakerphone) is broken. I tried to reseat the cables multiple times and nothing worked! Any suggestions? Parts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Brady, thanks for the input! I appreciate you getting back. I reseated the audio cable 5 times, while it was open i tested it, i think the heat gun may have damaged the sensor and the audio? What part can i buy, i need to get this fixed! The cable does not looked damaged. Any ideas?
完成的
Heat Gun?? you only need to use the heat gun for like 5 seconds on low. it doesnt take much to get the adhesive hot.
完成的
添加一条评论
3个答案
最有帮助的答案
It sounds like (no pun intended) cable #3 is not fully seated within the connector on the logic board or the connector/cable is damaged. Although you have tried re-seating this connector, it never hurts to try again. Also, does the cable itself or the connector on the logic board appear physically damaged in any way? Make sure the connector's locking bar is flipped up before sliding the cable into the connector. Good luck!
这个答案有帮助吗?
得分 4
2条评论:
In reply to: Re: How can I repair my iPhone 3GS' speaker and motion
sensor?
Brady Cabe wrote:
Although iFixit does not sell that part individually, the
contains iPhone 3GS display assembly that cabling. Good
luck!
Brady, not sure what you mean here, by "the contains" please advise! thank you.
完成的
It looks like a few words were missing there. Ha, sorry. What I meant to say is that the iPhone 3GS display assembly contains the cable you need to replace. Granted the part includes much more than you need, but because that cable is not sold separately, that is the best thing I can suggest at this point. Sorry I don't have a better answer for you :(
完成的
添加一条评论
@ollie: it's normal that there's some space in between the white line and the connector. I've repaired several iPhones and I've never managed to get the cable in any further. BTW, dunno where you read that crap, but the lock is never gonna close by itself, no matter how hard you push the cable...
@the others: sorry for posting this as an answer, but I can't comment (yet?) and I couldn't find any PM system or the like
这个答案有帮助吗?
得分 0
添加一条评论
im having the same problem, i just chanced the camera
my prox sensor, speaker and my lcd backlight is gone
这个答案有帮助吗?
得分 0
1条评论:
If the above answer did not solve your issue, please star a new question and state your symptoms. This question is 2 1/2 years old.
完成的
添加一条评论
添加你的答案
Mike Larson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 43,331
