跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
What's wrong? Replaced mobo but new battery won't charge.
Hi ifixit community, hoping you can help me on this one.
I replaced a water-damaged Macbook (mid-2008) logic board and it now works, however it doesn't work properly when the battery is plugged in.
I figured it just needed a new battery but even the brand new battery does not charge in the Macbook nor does the Macbook function properly with it plugged in.
Remember the Macbook works fine off the wall charger with no battery installed.
What component still needs to be replaced to get this to work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The water damage might have also affected the battery connector. I would try replacing that piece. Another possible problem is that in some macbooks, there are "energy star" versions and "non-energy star" versions of the logic boards. You might've replaced yours with the incorrect version. I don't know that that would cause the problems that you speak of, but it is certainly something to consider. You can check your old and new logic boards by looking for the words "energy star". Energy star versions will say "energy star" somewhere on the board, where as the non energy star versions will not.
Good luck!
这个答案有帮助吗?
得分 3
3条评论:
That sounds about right, thanks! I noticed some blackened pins on the battery connector when I had taken it apart the first time... maybe that should have been a head's up. To be honest, I figured it was that part but I didn't know what it was called.
完成的
Or if it was the possibilty it was anything else, for that matter.
完成的
This did not solve my problem, unfortunately. Is it possibly the inverter?
完成的
添加一条评论
添加你的答案
RZephyr07 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 2,491
