跳转到主内容
加入维修社区 - 创建账户
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
continually searching with/without sim
Changed a kit on an iphone 4 three months ago...been fine....now all of a sudden it just says searching for a signal...doesnt recognise me taking sim out or putting it in...
Must be somebody clever out there who has the answer :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
2条评论
Are you running ios 6?
完成的
Go to settings, tap cellular and on the cellular data, enable 3g and the data roaming after that remove the sim card and put it back.
完成的
添加一条评论
15个答案
已选择的解决方案
this is a date/time error. Join your WLan with the iPhone or manually set the date/time. Remove the sim card and put it back into the phone. Now you can enter the sim-code.
这个答案有帮助吗?
得分 20
22条评论:
You're the best. I tried 3 hours to fix it. Tried everything, hardware , coils everything...and your solution fix it...incredibile. Thank you!!!!!
完成的
you're the best man, i almost killed my iphone 4s today and thank God i found your post in time... it was just the date and time and now it's working...
完成的
I had same problem. I thought it was hardware and trying for days. I fixed the date and it is fixed. So simple and yet so difficult to find the solution. Brilliant solution from ifixit. thanx
完成的
thanq thanqqq dear u r the best.........
完成的
Awesome! thanks much for the solution
完成的
显示更多的17条评论
添加一条评论
Put another persons SIM card in your slot, wait 2-3 minutes, have someone dial the phone number of the SIM card you placed in your phone, pick up when it rings and let it sit idle for about a minute before hanging up...your phone should recognize that card and then you can remove it. Put your card back into the phone, if your phone doesn't recognize the card, your SIM card is damaged most likely, call your service provider, they can check it over the phone ;). Mine was a bad SIM card.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much. I was desperate and wanted to give my new iPhone to the service. Now it works!
完成的
添加一条评论
i reset my iphone 5c with this same problem.. now i cant activate it.. its still always saying "searching..." any solutions?
这个答案有帮助吗?
得分 1
2条评论:
完成的
Me also have the same problem...I can't activate my iphone 5c now...
完成的
添加一条评论
my iphone says searching all time even without the sim card _ and if i lock it,its gonna come lot of languages changing on the screen..................plz help me if u know whats going on!!!!
这个答案有帮助吗?
得分 0
1条评论:
My iPhone 7 is searching and imel number corrupt
完成的
添加一条评论
Hi!
I just joined ifixit to say THANKS. This procedure solved my problem, THANK YOU AGAIN!
这个答案有帮助吗?
得分 0
添加一条评论
i raed Mark's answer which has worked for many, but those steps are not working for me, can someone please help, really desperate.
Cant understand why its not working for me. What is sim code is it same as sim pin, then i can't edit that
这个答案有帮助吗?
得分 0
添加一条评论
My wife gave my daughter her iphone and suspected she broke it. Cellular dealers were saying it was a damaged sim reader. The iStore wanted money just to book a techician to look at it. Thanks.... This is a great post that saved me money and fustration!!!!
这个答案有帮助吗?
得分 0
添加一条评论
If this works i Will appreciate, but i have a problem....
I dont find the solution so, i restored my iPhone 5c by iTunes
Then, i can't register my iphone trought wifi way, and iTunes way too.
I was investigating and then i put the iPhone in recovery mode, and the process wont complete because an error from itunes. I stay here. If you help me i Will love you forever...
(Sorry For my english)
这个答案有帮助吗?
得分 0
1条评论:
i cant active my iphone 4 ,same problem are any sorte out this
完成的
添加一条评论
Hi.
I got the same problem. I done what is the first message sad but it dose not working for me. some reason . I got a ipone 4s.
I would be grateful if you could help me with it.
Thanks very much.
Krisz
这个答案有帮助吗?
得分 0
添加一条评论
i try to change time/date and no affect
help me plz
it is seaching ONLY
这个答案有帮助吗?
得分 0
添加一条评论
When time and date change toggle airplane mode for 10 seconds if that fails turn phone off and on
这个答案有帮助吗?
得分 0
1条评论:
Still searching !!!
完成的
添加一条评论
This is not working for me. I using iPhone5s. Kindly help me pls. what is that sim code.My Date/time is correctly only. But still i have this problem. My phone is still searching with or without sim. Is it a hardware problem nor software? Kindly guide me
这个答案有帮助吗?
得分 0
3条评论:
And i also tried my sim with other phone its working cool. And other sim is not working in my phone. So i guess sim is in good condition.
完成的
Man your cellular IC is gone like mine...got it fixed today...they replaced the IC
完成的
How much did it cost
完成的
添加一条评论
Tried everything didn't work
这个答案有帮助吗?
得分 0
添加一条评论
really very helpful you sve my lots of time and money also very thanks marks.
这个答案有帮助吗?
得分 0
添加一条评论
My ipad 3 is just showing searching with out sim in it, also have updated to the lastest Os but I could not install. Kindly help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
splodger 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 39
总计 77,643
