跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
SSD + RAM install - only beeps
Hello-
I have a brand new 2.8GHz 21.5" iMac that I turned on once and did a software update with. I turned it off, followed the guide on here and installed a 256GB Samsung 830 SSD. I believe I did each step completely with no surprises. The final step before turning the machine on was to swap out the OEM 8GB RAM with (also brand new) 2x 8GB Crucial DDR3L 1333.
When I push the power button I hear the HDD spin inside for ~1/2s. About 3 seconds in I hear a single beep that just repeats every ~5 seconds. If I let this continue for 5 or so beeps, the fan turns on full throttle and stay that way. Unplugging the computer and trying this again a few minutes now have the machine turning on with the fans already on full speed.
This leads me to believe it's the RAM - I tried both slots (one on top left, one on top right... one on bottom left, one on bottom right). No luck.
I tried the original 8GB of RAM. Also no luck. Again, tried both top and bottom.
Any advice would be greatly appreciated... perhaps I missed a connector?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sheesh, I feel stupid.
Problem solved - I plugged the LCD thermal sensor into the wrong receptacle. It didn't even fit! Goes to show how these types of things benefit from a good light source :-P
Whew, glad that got worked out quickly
这个答案有帮助吗?
得分 1
1条评论:
Hello sebstewart, Please change your comment to an answer and accept it so this question may be archived to help future users. Thanks.
完成的
添加一条评论
The issue is RAM, see here.
It seems (I dont know your exact model) that 4gig sims max per slot is the limit, from here.
"For the iMac (Mid 2010) and iMac (Mid 2011) models, use 2 GB or 4 GB RAM SO-DIMMs of 1333 MHz DDR3 SDRAM in each slot."
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sebstewart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 1,209
