跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
问题已关闭
Fusion Drive- What is it?
What IS the fusion drive?
Is it one drive enclosure with both a solid-state storage and a magnetic drive inside? Or, are there two different drives in the "fusion drive" mac mini that are individually interchangeable?
Are there two sata cables, or just one?
I looked up the part number for that drive, but found no specs, just a few for sale...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Update: Here's the breakdown of a Fusion drive from a Mac Mini Arstechnica. Turns out its two devices a HD and a SSD which requires two drive bays.
这个答案有帮助吗?
得分 2
1条评论:
It's a little early on knowing exactly whats going on inside a Fusion HD.
From what has been disclosed so far its a Hybrid hard disk, a disk drive with a SSD in one device. Similar to Seagate's Momentus XT Hybrid HD. What Apple did state is some firmware in the drive that copies the OS files to the SSD. While the Seagate can also do this inherently when you first run it. You don't need to do anything for it to work so I'm not sure whats so special here other than the size of the SSD. But as I stated its too early to know for sure.
Here's a writeup from Forbes and what some people are thinking.
完成的
添加一条评论
Support Apple document about Fusion Drive:
http://support.apple.com/kb/HT5446
Regards
这个答案有帮助吗?
得分 0
添加一条评论
What would happen if you took out the fusion drive and, say, tried to use it in an enclosure? Would you see the SSD and the HDD or is the software built into the drive and not OS X?
这个答案有帮助吗?
得分 0
1条评论:
I think your pushing it here. First we're not sure if the Fusion drive is really a single device or not. Then you loose the benefit when you go thru USB or Firewire interface.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 8,234
