跳转到主内容
加入维修社区 - 创建账户
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
My Mac Pro don't start the OS X Leopard
Hi,
My Mac Pro start the OS X Leopard after Apple Logo give a kernek panic.
I test everything, inclued with ASD 108 for my Mac e don´t detect nothing worng.
Any body who idea what going on?
Thanks a lot.
Regards.
Att;
HkN
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You sound like you are describing a ram issue. The ram is by far the most likely cause of any kernel panic that your computer experiences. I would remove all the ram sticks in your computer. This guide will show you how to remove an reinsert ram into your computer:
http://eshop.macsales.com/tech_center/ma...
After you remove all the ram, reinsert 1 stick into slot 1 and boot up. If there is a kernel panic, then reinsert a different stick and try again. This will show you what ram sticks are bad (kernel panic) and which ones are good (boot up). If you get a kernel panic on every trie then you most likely have a different problem. You ram might also need to be removed and reinserted. You cannot use a ram stick it it is bad. You may even want to buy new set from OWC to replace the aging set that you currently have installed. If this is not the case, then you may also want to try the hard drive. Hard drive caused kernel panics are far less likely but are still a possibility for any mac. Tell use what you find so I can provide any further assistance if needed.
Hope this helps.
这个答案有帮助吗?
得分 2
1条评论:
If all sticks are bad in slot one try slot two. +
完成的
添加一条评论
Hardware issue. Could be a bad processor or bad RAM.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
HKN 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 9
总计 571
