跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Replaced the hold switch and now click wheel is not working.
I have pulled apart my 30GB iPod video again to make sure I didn't miss anything. I have also done a restore with Itunes. The reset function works fine (holding the menu and center button until reboot). Toggling the hold switch on and off works fine as well. No response at all on any of the buttons other than the reset function. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
Retake it apart. Buttons may be stuck.
这个答案有帮助吗?
得分 2
添加一条评论
The click wheel has to align in a specific way...if im not mistaken 3 little holes on the bottom of the click wheel button should help you align with ribbon cable...do you hear click sounds when pressing the button?...if not then its not align properly
这个答案有帮助吗?
得分 2
添加一条评论
Check and recheck all ribbon cable connections, this is most likely where the problem is. Sometimes they appear all the way in but are not quite making contact.
这个答案有帮助吗?
得分 1
添加一条评论
When openning you broke your click wheel cable or you dont have it grounded because the tail ribbon of the clickwheel came of the frame of the iPod so know you iPod will not work
I hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 6,801
