跳转到主内容
grey wire broken at batterie connector
Repairing my MacBookPro (end of 2006) a light grey wire broke, which is soldered to the connector for the batterie.
Guess the soldering on that white connector is so fine, that I can not fix this with a "normal manual" soldering job.
The machine works fine.
What purpose has this light grey wire?
What hardware function do I loose?
What can go wrong with my MacBookPro?
Can the entire connector with the wires be replaced?
(Would like to attach a picture, guess this is not possible)
Update
Thanks for the help to everybody.
The case can be closed.
As the Mac works with this wire broken/disconnected....
....so I do not know what hardware function do I really loose.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
It is a power wire - you can probably find a replacement cable from a parts supplier or from a similar model MBP with other issues (broken display for example). There is even a guide for how to safely remove the connector.
If this answer was helpful please remember to mark it accepted.''
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
paul 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 4
总计 653
