跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Some of keys doesn't work after I spilled water.
Hey.
I've spilled a little water at the left-bottom of my keyboard,.
Now, when I type, some of keys doesn't work, and sometimes one key types a lot of characters together!
What actually happend, I don't know,
What should I do now, I don't know, :(
Anyone could help me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
This will most likely require your keyboard to be replaced. Two ways to get this done, you could replace the whole top case or you could replace just the keyboard. Replacing just the keyboard would require unscrewing several tiny little screws to unmount it from the top case assembly, but it can be done.
这个答案有帮助吗?
得分 2
2条评论:
So it doesn't need to replace the Logic Board, does it?!
also how much replacing the keyboard cost?
Thank you.
完成的
In my experience if the computer still powers on and the only symptom is an erratic keyboard, the logicboard is most likely fine.
If you do the repair yourself, the replacement keyboard can be found online for $50-$100.
完成的
添加一条评论
HI
I had the same problem... Some keys types lot of characters, and I don't find any guide to helpme...
Please, help us!
这个答案有帮助吗?
得分 0
2条评论:
Ahaa, thank you. :)
完成的
Same problem here. Spilled some bottled water on the keyboard. It ran a while before being turned off (bad mistake). After drying it out overnight, about half of the keys on the keyboard don't work, others generate additional characters. Left mouse click doesn't open applications, need to select "open" and then it opens. Could this all be in the keyboard, or is my logicboard also bad? Is there a guide to replace the keyboard? In January 2016, is it worth fixing this MBP. Is was working perfectly before it got wet. I'm concerned that if I replace the keyboard, there may be other problem (logicboard?).
Need some advice.
Thanks
Vee
完成的
添加一条评论
添加你的答案
Mohammd Aljaber 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,547
