跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
How to choose memory and clean the fan?
I want to upgrade RAM for my Mac Mini 2011. I know it uses DDR3 1333 Mhz, 204-pin modules, but when I search, there are modules with greater speed, e.g. 1600 Mhz? Will these faster pieces make my Mac run faster or is 1333Mhz already the limit?
And when I open the machine, I saw some very fine layers of dust gathered on the fan blades. How can I clean them out?
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
To clean the system of dust I would get a small/medium soft painters brush (cheap hardware store kind). Carefully wipe the areas down (you don't want the brush to snag anything) then use canned air to blow the loose stuff away.
As to the memory stay with the same speed is best.
这个答案有帮助吗?
得分 2
1条评论:
Many thanks Dan.
完成的
添加一条评论
添加你的答案
cody 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 996
