跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
227 个问题 查看全部
Do I have a defective battery?
I have replaced the battery of my iPod Photo 30 gb (model 616-0206) with your iPod 4G/iPod replacement battery 950mha (part IF 193-016-1)and it doesn't hold its charge more than 3/4 hour in working mode and 2 days in shutdown mode. Is it possible that it is defective? What is the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Make sure that both batteries are the same size and amps. Also do a firmware restore in iTunes to eliminate issues that could be causing charging issues. Try out the restore and get back to us. Good luck!
-Varsity
这个答案有帮助吗?
得分 1
添加一条评论
I buy a iPod 4G/Photo Replacement Battery 3.7v 900mAh and install correct way, but is not charge, i use origial usb charger.. my ipod is de photo 20Gb. what would be?
这个答案有帮助吗?
得分 -3
2条评论:
Please write your own Question on the [www.ifixit.com/Answers|Answers page], rather htan piggybacking another question.
完成的
Ditto to Ben's comment
完成的
添加一条评论
添加你的答案
paullouwies 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 2,635
