跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Where is the Airport Antenna?
Hi !
I've got the "No Airport Card installed" syndrome ...
I did my own researches and decided to open the MBP and check the wires : no improvements !
Then I changed the airport card following a guide on this website : no improvements !
So I'm wondering if the failure comes from the antenna ...
I've given a close look to the LCD dismantle and this antenna seems to be in the bottom of the screen, and there might be no use to open completely the screen (heater gun, etc.)
Is that correct ? Am I in the right way to solve my problem ?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Did you reset your PRAM and SMC after disconnected and reconnected everything? If not give that a try. Also check and see if you have any other USB devices (iSight, ports, etc...) not working, the Airport is piggy backed into the USB.
完成的
添加一条评论
1个答案
已选择的解决方案
"No Airport Card Installed' error implies the system can't see the Airport hardware not an antenna issue. I suspect you have a bad airport card (depending on the source where you got the replacement) or the ribbon cable is bad are the likely suspects.
Can you explain what happened before you had this problem. Did you drop or get your system wet?
这个答案有帮助吗?
得分 1
6条评论:
I suspected the airport card first so I bought another card on Ebay ... (and I can't test it on another laptop) I checked thoroughly the black flat cable, it seemed OK ... and gave a close look to the 3 small cable of the antenna, seemed OK too ... And for information, I had a "little" bike accident which may have caused this error ;o)
完成的
Ouch! So the question is was the system in a padded case or did it get dented some where? It could be the bounce damaged the ribbon or the main logic board connector. Any visible signs of damage anywhere?
完成的
The mac was well protected but still, there is small dent on the front bottom right corner ... So you think the ribbon or one of the connector is responsible for this ? not the airport card ? or a "short circuit" on the antenna ? thx
完成的
You state bottom right so the display lid did not get dinged correct? Just the corner of the main case its self. If thats correct I don't see how the antenna its self or the cable could have been damaged. Does it look like the antenna cable was pinched or squeezed by the damage? The bottom cover its self is not dented at the airport causing it to short on the antenna connectors? Does it work without the cover?
完成的
At this point you'll need to try swapping out the ribbon cable, if you think the airport card is good. It would be helpful having a second good system to test out the parts to isolate this down.
A sudden shock can displace a SMT component/connector or cause damage that is hard to see.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
sebastienbeunard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 864
