跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
HOw do I connect the top part of the volume/lock ribbon cable?
I soldered the ribbon cable down to the logic board by the volume buttons, but I am a bit confused as to how I connect the upper part of the ribbon cable (The part that is for the lock button). Is there soldering involved, can someone please help me? Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hey Federico,
There is no soldering involved. There are two screws on the top holding power/lock button bracket in place. What I usually do is to first put the whole cable in place. So first screw in the lock button after screw in the volume button and than at the end I solder it to the board.
Hop that makes sense.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
federico 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 428
