跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36476 个问题 查看全部
Voice controle starts on its own
Hi,
i have a iphone 4 with a water damage. The Problem was that the Power button and the home button doesn´t work and that the voice control starts up automatically.
I replaced the power and the home button (also the cabel) and the iphone work again.
But the problem with the voice contral was not solved.
Has anybody an idea whats the problem or what i can do?
Thanks for your time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hey Marcel,
You will need to replace home button flex cable in some cases you also need to replace the whole charging dock assembly.
Hope that helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marcel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 531
