跳转到主内容
戴尔台式机的维修指南。
Why won't Windows XP recognize the keyboard?
Hi, I have a dell desktop that will not recognize the keyboard but it will recognize the mouse. It will turn on the num lock light. Windows just won't listen to it. I checked the ram and replaced the cmos battery and thatngot the mouse working , but nothing else, and yes the keyboard does work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
u guys dont understand, it cant b recognized even at bios stage, 6 usb ports, no ps2 connector... what a dell system!, or show me hw 2 rewire a usb to a com port let me try.
完成的
添加一条评论
3个答案
已选择的解决方案
Check your drivers,
Control panel>hardware and sound> Device Manager
In Device manager there will be a tab Keyboard, check if it is up to date.
I know if its a USB keybored i think it will say P/P or plug and play device, or plug and play keybored.
这个答案有帮助吗?
得分 1
1条评论:
tired of you idiots cant give correct answer
完成的
添加一条评论
You can also buy a PS2 adapter if you have a usb keyboard.
这个答案有帮助吗?
得分 0
添加一条评论
You need to first check the keyboard on some other PC if it works fine or not otherwise try changing the port if its usb. If in case of none of the keyboard is working via USB then try a PS2 keyboard or try updating the drivers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
thelectronicnub 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 16
总计 7,844
