跳转到主内容
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
iPad Digitizer Replacement and Repair Problem
Hello
I am repairing an iPad 3 digitizer.
After removing the broken digitizer, I was testing the new parts and all was well at that time.
Don't ask me how, but I almost dropped the unit during this testing phase. No adhesive was applied, and it basically fell into the three pieces while turned on.
The LCD display cable came unplugged while the unit was powered on.
At this point, the device does not display anything at all now.
How do I determine if it is the display or the logic board that has failed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Hey Vince,
After you plug or unplug the LCD while your iPAd is on you need to perform hard reset by holding power and home button down until you see apple logo appear on the screen.
Of course this will only work if you did not damage any of the flex cables or connectors.
Hope this will help.
这个答案有帮助吗?
得分 2
1条评论:
John
I had tried the hard reset first, but after reading your post, I went back and tried it once more.
The device powered on and is functioning.
Kudos.
完成的
添加一条评论
添加你的答案
Vince 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,630
