跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Can Apple Tell If I Dropped My Phone?
Are there any sensors in the iPhone that indicate that the phone has been dropped that apple could use to tell me my warranty is void? I know they have moisture indicators, but never have heard of shock indicators.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Yes, they can tell that you dropped your phone I have just been to the apple store to run diagnostics on my iphone 5 and they told me thy i had dropped it 4 times, which was true. I never asked how they knew as i was worried that it might void warranty (but it didn't because the dammage wasn't directly because of dropping - it was a speaker problem not a cracked screen for example)
这个答案有帮助吗?
得分 3
1条评论:
say what? maybe they can check the gyroscope history?
完成的
添加一条评论
They can use the accelerometer logs from the phone itself to tell instantly. Also damage even subtle is noticeable on the inside of any apple device.
这个答案有帮助吗?
得分 2
添加一条评论
No there is not shock indicators in any iPhone Apple has made. It is too expensive to place that time of tech inside a device as small as an iPhone.
这个答案有帮助吗?
得分 0
3条评论:
It's called an accelerometer and it is indeed inside the iPhone.
完成的
iPhones have had access and gyros for some time now.
完成的
@Barack Trump You do realize this post is over 10 years old, don't you? There's really no point in responding to these very old questions unless you have significant new information to add, which I honestly don't see in your response.
There are many recent unanswered questions that could better use your input and experience.
完成的
添加一条评论
添加你的答案
christopher 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 103
总计 18,504
