跳转到主内容
How to remove a cd stuck inside my mac?
A cd has been stuck inside my mac for almost a year. The guy at the Apple Store tried to fix it, doing all sorts of trick on the keyboard, and also using a bit of cardboard inside the slot.
Didn't work.
He said I have to send my mac for repair, which will cost a small fortune, and it's without any guarantee it will work afterwards.
So, any tips?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The Apple Store guy was most likely right but if you are handy you can pull the drive yourself and take out about 6 screws on the drive and remove the disk. Then put it all back together and hope for the best.
Here are the instructions for removing the drive:
iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement
And if you need it here is a replacement drive:
http://www.ifixit.com/Mac-Parts/iBook-G4...
Many options but choose the one you need if you still need it after pulling apart.
Good luck
这个答案有帮助吗?
得分 1
添加一条评论
There have been quite a few questions about this already. Here is a search for other questions about the same problem and answers for that problem.
这个答案有帮助吗?
得分 0
1条评论:
Thank you, I had some problems figuring out this site.
完成的
添加一条评论
添加你的答案
Idun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 5,264
