跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
No input/output Audio Devices
MacBook 13" Unibody (Model A1342) Mid 2010 , Mac OS X (10.6.8)
The sound suddenly stopped. On System Preferences, on Audio, it shows the sound as muted and doesn't allow me to unmute it. System Profiler shows Audio (Built-in): Intel High Definition Audio: Audio ID - 0, no input/output Audio Devices. I fixed the hard drive access permission , did the reset for both pram and smc several times and finally installed a clear copy of mac OS after deleting the HD, but unfortunately ended with no success. Do you think it is a hardware related problem? How do I fix this?
 Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hello Mary, Apparently Apple has a problem with the 10.6.8 update having to do with audio. I am including a link to a discussion on the subject. Hope this helps you.
http://support.apple.com/kb/HT4561
Including a link to the support page also.
http://support.apple.com/kb/index?page=s...
这个答案有帮助吗?
得分 2
添加一条评论
Thank you for your reply. I installed the update and restarted the computer but with no luck. The advanced hardware test i run shows no errors!!!Do you have other suggestions? thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 1,987
