跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
Why won't my 32GB CF card work?
I've got an iPod Classic 80 GB model that won't boot when I perform a compact flash conversion using this part:
http://www.dealextreme.com/details.dx/sk...
or this part:
The CF card is good, as I've swapped it with the one working fine in my upgraded 32GB iPod mini.
Can anybody recommend an adapter that works for this upgrade, or perhaps explain why I may be barking up the wrong tree?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Yeah. Should have mentioned that. I tried formatting it both in HFS+, which I've read works best if you're primarily a Mac user, and in Fat, which I read works best with windows. No luck either way.
完成的
Yeah. And just to be sure, I tried it both ways.
完成的
Hmm... Can you put the original hard drive back into it, and see if it will work then?
完成的
Nope. Original hard drive was kaput, which was why it was for sale. I may have a line on another broken one of the same line. That should tell me if it's an adapter issue, or if there is more substantial trouble with the iPod.
完成的
If it can't read it, then I would have to conclude that the adaptor is bad. Can you boot it into disk mode, or diagnostic mode?
完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
did you format it with the right scheme? i believe they these use the FAT filesystem.
这个答案有帮助吗?
得分 1
1条评论:
Did you put the ZIF cable in facing the right way?
完成的
添加一条评论
最有帮助的答案
Hi,
i used the first adapter with an 1GB CF-Card to give it a try and it worked fine. I didn't used a special format and let it up to iTunes to format the card. Maybe its a problem with the compability between the adapter and the card.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Joseph Manning 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 5,623
