跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 个问题 查看全部
New battery only charges to 52%
I bought a replacement battery for my macbook pro (mid 2009 15 in.,2.66ghz) after replacing the battery it will only charge to 52%. I reset the pram and the smu ,but I get the same result. Hardware readout and coconut say the battery is fine, but I did notice that the amperage from the macs power readout for the battery is negative.
Any ideas what could be wrong, or is it just a defective battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
By new, do you mean, brand new or second hand new? You can use this app to diagnose your battery. http://www.coconut-flavour.com/coconutba...
完成的
The battery is new from DV Wharehouse. I used the Coconut app and the battery seems fine.
完成的
添加一条评论
1个答案
已选择的解决方案
I have seen new Chinese batteries fail straight out of the box... you should contact the vendor about this.
If this answer was helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
nsolo100 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 636
