跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2512 个问题 查看全部
iPhone back housing Replacement
Is the iPhone back plate harder to replace than the 4s?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
5个答案
最有帮助的答案
The back of the iPhone 5 is a back case. It is virtually the entire iPhone, so will be among the hardest iPhone procedures. At least there is no bezel to figure out how to remove and transfer.
这个答案有帮助吗?
得分 3
添加一条评论
Brad is correct, The rear case is now the body of the phone. To replace this you would need to perform a full teardown. If you would like to take a look then here is the link for the Teardown guide: iPhone5 拆解
Regards,
这个答案有帮助吗?
得分 0
添加一条评论
you can buy them here for $188
but as brad said, it would be a fairly massive job if you have no repair experience
http://www.aliexpress.com/store/group/iP...
这个答案有帮助吗?
得分 0
添加一条评论
Check this video for full iPhone 5 Teardown it does not look that hard. : )
这个答案有帮助吗?
得分 0
添加一条评论
That teardown is a bit brutal on some of the parts. :)
What about the glass parts of the back case? If one of those is shattered, can you remove it from the outside and glue a new one in? I know they're matched by super robots or whatever, but since that's the most likely damaged part on the back it seems like a pain to dismantle the entire thing to replace that glass. :/
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lanejsl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 52,811
