跳转到主内容
加入维修社区 - 创建账户
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Is 'digitizer ribbon cable' of nexus 7 replaceable?
I have accidentally cut digitizer ribbon cable of Nexus 7, can it be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Assuming this is what you cut, you should be able to replace it.
Otherwise you might have to replace the whole display assembly, but I would try the LCD cable first before replacing the whole display assembly.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for your response =), thats not one which I broke, but I was able to get my cable repair from local market.
完成的
Hi Naveed, did you get the guy from the "local market" to replace just the cable? Mine got pulled off as well and as far as I can see, the ribbon is stuck to the digitizer by some sort of adhesive. Not sure how that works with establishing electrical connections though.
Does anyone know how I can reattach the digitizer ribbon?
完成的
添加一条评论
Can be purchased here
http://www.ebay.com/itm/300829794936?ssP...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Naveed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 5,382
