跳转到主内容
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 个问题 查看全部
How do I reset a frozen screen on my razr?
I was in a call, & when I tried to end it, my phone froze. Now it is stuck with the call display still showing, and it won't let me do anything. I can't turn it off, and with no battery to take out, I have no idea how to reset it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
my razer cannt switch on.. only after the razer logo out then its off again.. helep helepp
完成的
添加一条评论
13个答案
已选择的解决方案
I would suggest removing the battery for a few minutes. It's not the most difficult thing to get to.
Motorola Droid RAZR Battery Replacement
You don't need to actually remove the battery, just unplug the terminal for a few minutes.
这个答案有帮助吗?
得分 3
1条评论:
My phone is not working after battery replacement and stopping on Intel what I have to do please help
完成的
添加一条评论
最有帮助的答案
My phone did the EXACT same thing. This is the fix that worked for me since the Razr doesn't allow you to take the battery out:
Hold the volume DOWN button + Power Button down at the same time for 10-15 seconds and the phone will power off. It might just restart. If it doesn't, wait 20 seconds then power it back on.
VOLUME DOWN BUTTON + POWER BUTTON held down at the same time for 10-15 seconds. This will power the phone down. Then you can turn it back on!!
这个答案有帮助吗?
得分 25
18条评论:
Thanks so much! It worked!!!
完成的
Worked for me too! Thank you!
完成的
It worked for me too. Thanks for this very helpful information.
完成的
Great Advice!!!!!!!!! It worked!
完成的
I was in a panic!! This worked!!!
完成的
显示更多的13条评论
添加一条评论
Yay! Thank you for the advice of Volume Down & Power at same time for 15 seconds, it worked!!!
这个答案有帮助吗?
得分 1
1条评论:
yes this was the only thing that worked for me thanks.
完成的
添加一条评论
hold volumn down + power button together worked for me to. thank you
这个答案有帮助吗?
得分 0
添加一条评论
Just worked for me too! thanks
这个答案有帮助吗?
得分 0
添加一条评论
don't take your battery out voids the warenty power + volum down works
这个答案有帮助吗?
得分 0
添加一条评论
Omg you're amazing, was about to bring my droid razr into Verizon because nothing worked and it's been frozen since yesterday, but this simple trick worked! Thanks!
这个答案有帮助吗?
得分 0
2条评论:
Does not work all of the time. First, just to get the Motorolla icon to appear can take 20 attempts. Then, most people are afraid that a complete restore will him to lose all files - does not happen with my Iphone - so he is left with turning it off, then if on again, same problem. Also, his requires to hold onto power button once green light comes on to get to any menu. Solution - get an Iphone.
完成的
Worked great for me. It only took once, not twenty. Didn't lose any files.
完成的
添加一条评论
wow - genius! thanks! I was about to head to Verizon also!
这个答案有帮助吗?
得分 0
添加一条评论
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!I was also about to take it to verizon because nothing worked including holding down the power button...holding the volune down at the same as the power worked! Much appreciated :)
这个答案有帮助吗?
得分 0
添加一条评论
I did that. But everytime I turn it back on it freezes turning on and its been like this for two days now. What do I do now.
这个答案有帮助吗?
得分 0
添加一条评论
thumbs up !!!!!!!! bravo !!!!!!! it worked, by pushing volume down + power button at the same time. great........ mir of pakistan
这个答案有帮助吗?
得分 0
添加一条评论
My Motorola Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
What should I do to recover it.
Thanks....
这个答案有帮助吗?
得分 0
添加一条评论
i have the same problem My Motorola Droid Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
Kindly guide....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
susyq 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 65
总计 28,246
