跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
Battery removal, torn black outer material - dangerous?
I'm changing the rear, aluminium casing on an iPad 2 which obviously involves prying up the battery from the large amount of adhesive that it's stuck down with.
I did this as carefully as possible, but a small amount of the black material or 'film', that covers the battery was left behind on the old casing adhesive.
This has exposed a small area of the battery (I can see a silver layer underneath) and the battery also now has a 'chemical' or 'solvent' smell to it.
The three cells have also bent very slightly during the removal process (it seems almost impossible to me to get them out perfectly flat)
Is this battery still safe to re-use or do I need to buy a replacement?
If I do need to replace it, is it safe to store inside my house in the mean time or is there any risk of fire/explosion?
Thanks in advance for any advice.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
If it is a strong chemical smell then I would replace it without thinking twice. It's not worth the risk. I have seen damaged batteries reused in ipods and it never turns out well.
这个答案有帮助吗?
得分 3
添加一条评论
Time for a new set of cells - Even if the cells are not leaking now you have a hole which the chemicals can leak out and if the metal contacts the case things could also short out.
A time bomb waiting to go off!
这个答案有帮助吗?
得分 2
2条评论:
So then, how should I dispose of a torn battery?
完成的
Contact your local battery recycler
完成的
添加一条评论
If you can smell it, you need to replace it. We've had an iphone 4s battery explode in our shop. Not something you want to happen ;)
这个答案有帮助吗?
得分 1
添加一条评论
I tore a hole in the fabric and it is tiny. I can see a needle size hole in the fabric when I pried the battery out of the adhesive. No smell or damage to the cells just a minor splinter or damage to the outer skin. Is it still ok to use it?
这个答案有帮助吗?
得分 0
1条评论:
[image|2128922]
This is the battery that has the tare on it.
完成的
添加一条评论
添加你的答案
simon evans 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 28
总计 10,732
