跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Wifi (in grey) could not be turned on?
Tried rebooting & hard reset, but it didn't help.
Also, tried to turn on & off airplane mode.
Same result.
Even for bluetooth, when I tap on it, it kept processing but can't be turned on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
That's a baseband problem with the Mainboard and as far as I'm aware is either not fixable or not cost effectively fixable.
这个答案有帮助吗?
得分 0
添加一条评论
Definitely hardware. If it is in warranty and no other issues Apple will replace it. Don't forget to backup first.
这个答案有帮助吗?
得分 0
添加一条评论
I have got the same issue with my iPhone 4S since updating it to iOS 6.
No Wi-Fi & Bluetooth connectivity.
Will the problem get I have tried all the software solutions, resetting & restoring my iPhone.
Nothing seems to be helping.
Will replacing the Wi-Fi antennae help?
I bought my iPhone in Pakistan from a reseller & there's no warranty of any sorts.
So getting any assistance from Apple is out of the question.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,818
