跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Whys is my iPhone 4 display showing darker areas and scanlines?
I opened my iphone to change a broken dock connector and the volume switches now they work but I have a new problem.
I'll do my best to expain... There seems to be an inconsistency in the intensity of the brightness. It seems like the dark areas are being brighter than they should.
However, whenever there is something very bright, like white or close, in the horizontal bands that contain the white areas, the intensity of the black areas enclosed look correct.
Do you think I need to replace the lcd assembly or could it be easier?
I know, it's tricky to explain so here are some pics. Unfortunately I couldn't get to photograph the scanlines.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Have you checked all the display connectors. Many times if there are any issues with a phone after a repair it is because something was loosened or not properly reset. I would check all the connectors inside an look for any debris that could be causing problem by shorting electronics out. i had a similar problem on an iPad and it was because a small metal shaving was shorting out the backlight connector. Just look over everything and tell us what you find and we can help you from there.
Hope this Helps
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 891
