跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
问题已关闭
when I power my ps3 on its in a different language
So I fix the ylod on a ps3 and it looks like a Japanese language comes up and give me two options to select. I cannot hit the x button on either of them so I press the o button and it gives me two other options. But no matter what I do after that it comes up with two sentences and that's that. I know the description isn't perfect but I don't know what is going on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
一つ。(設定)>(本体設定)> [システムの言語設定]に移動し、xmb™ホームメニューのボタンを押してください。
二つ。メニューから選択するために使用可能な言語のリストを提示します。お好みの言語を選択し、確認ボタンを押してください。
这个答案有帮助吗?
得分 0
4条评论:
What does that say
完成的
Ok I translated your comment and I did look it up what you said but the thing is. Is that I'm not even able to go to the main home page
完成的
Why are you not able to go to the main homepage? Regardless of the language displayed, you should be able to go through the menus as the layout is the same regardless of the displayed language.
完成的
I can't even do anything in safe mode
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 652
