跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Unable to remove display assembly
Hi,
I previously attempted to replace shattered glass on my iPhone but stupidly went for the cheapest option I could and only replaced the glass. The digitizer that came on the glass is a little iffy so I suspected that the cable had popped up when closing the phone. I then tried to open it up again forgetting that I should have left the adhesive to properly set afterwards. In doing this the adhesive won't stick properly to the glass to when I try to open it it only pulls the glass off and not the full display assembly. Are there any options to open it up again?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
I tried to reproduce your situation to see if I could remove the front panel assembly without using a suction cup. I was able to open the phone by prying in the narrow gap filled by the gasket between the metal bezel and the bottom edge of the front panel assembly. Plastic opening tools were not up to the task, but the pointed end of a metal spudger did the trick. An iSesamo would probably work well too. Any metal tool with a thin and flexible enough end might work but I would avoid knives or razor blades. These are brittle and may snap, flinging sharp nasty bits into your eyes. Use caution when poking and prying as there are tiny electronic components on the dock connector close to the bottom edge. The left edge of the photo for step 12 of this guide shows the components to avoid. Wear safety glasses and be aware that the front panel assembly edge gasket will be badly damaged.
Dual tipped metal spudger for more powerful prying, scraping, probing, and poking action. Perfect tool for opening an iPod or iPhone.图片
产品
Metal Spudger
$2.99
Springy steel blade features a smart tip design and a handle with a great no-slip grip. Effortlessly pops open iPod, iPad, iPhone and many other tablets, smartphones, and devices.图片
产品
iSesamo Opening Tool
$9.99
这个答案有帮助吗?
得分 1
1条评论:
I was going to try this but thought that this would be too damaging and that replacement adhesive strips were cheaper that a metal spudger so i just lifted the glass and replaced those. Thanks for the advice anyway.
完成的
添加一条评论
添加你的答案
Jacob Wilding 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 1,432
