跳转到主内容
EFI password reset, blinking folder? Death.
I'll get right to the point here. I attempted an upgrade from Lion to Mountain Lion. After the reboot, a blinking folder of ? death occured. Tried every keystroke I could find on the Internet to revive it, to no avail. I've tried to boot from my disk, and also from USB. Using multiple keys, multiple times. Option key is the only key that gets a rise outta my Mac. It displays the EFI password prompt. A password that was set by the previous owner I assume. I've attempted the ram removal trick which only makes a beeping sound. I've tried it with 1 stick in different slots and switching them around. Ugh.. Any other insight would be mucho appreciated. Oh I also bought a new HDD hoping I could just fresh install. Same problems. Help me? :(
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Try this:
How do I reset the firmware password on my MacBook Pro?
这个答案有帮助吗?
得分 1
1条评论:
Thanks. I meant to update this earlier. It turns out that I didn't try with the ram in the top slot. That worked. Pulled out the top stick, then the bottom, then put one back into the top slot. Turned it over, powered it up, held down the 4 keys to reset the PRAM and it worked!! Unfortunately, all my mischief under the cover caused my screen not to display a picture. It lights up but is black. :( Not sure what I did yet.
完成的
添加一条评论
how to fix bios password for mac book pro uni body ....It is harware or software to fix it this problem?
这个答案有帮助吗?
得分 0
添加一条评论
I think you can try to visit http://www.recoverlostpassword.com
这个答案有帮助吗?
得分 0
1条评论:
This site is for windows user only., not for Mac
完成的
添加一条评论
添加你的答案
mrmjweber 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 5,210
